BASE command
Changes the drawing’s base insertion point.
Icon:
Changes the drawing’s base insertion point for when it is inserted in other drawings, usually as a block or external reference. The base point can be indicated using X, Y, Z coordinates in the current UCS or by picking a point in the drawing.
Alias: BA
