BIMCREATEDETAIL command
Creates a detail and saves it in the Details library.
BricsCAD BIM
Method
Launching the command opens the Create Detail command context panel to let you define the detail in three steps.
  1. Detail type
  2. Reference solids
  3. Detail entities
  4. Detail volume inflation
  5. Name
  6. Category
  7. Insert detail reference
  8. Add general tag
  9. Solid Reference Tags
Detail type
Choose the type of detail to create:
Bounded
The detail will be applied to the selected solids to a length defined by the detail length.
Extrudable
The detail will be applied to the whole length of the selected solids (e.g. slab, wall, etc.)
Reference solids
Select the solids that define the situation where the detail should be applied. At least one reference solid must be selected in order to continue to the next step.
Detail entities
You can optionally select entities to add more detail in relation to the selected reference solid (solids).
Expands the sensitive zone of the detail to include similar solids which are not connected yet in the model. The edges of the initially detected detail volume are moved outward by the specified factor.
Name
Type in the name of the detail to be created.
Category
Select a category or enter a name to create a subcategory.
Toggles On/Off the insertion of detail reference in the model space at the place where the detail is created from.
Add general tag
Lets you add a new general tag. The newly added tag will differ in colour from those automatically added.
Note: You can also remove tags, previously defined automatically or manually.
Displays the automatically defined solid reference tags. You can remove tags by clicking the corresponding X button.
Note: The options within the command line reflect the options found in the command context panel.
