BIMGRID command
Creates 2-dimensional grids.
BricsCAD BIM
Icon:
Creates 2-dimensional rectangular and radial grids.
Method
The grid is created by specifying two points.
Options
Offset U
Sets the line offset between U lines in V direction (interdistance between the U lines).
Offset V
Sets the line offset between V lines in U direction (interdistance between the V lines).
Offset Labels
Sets the label offset to grid axes.
Radial
Creates a radial grid by specifying the center point, the start lines and the end lines.
