BIMIFY command
Analyzes the model and runs automatic classification and spatial location assignment for the entire model.
BricsCAD BIM
Icon:
Analyzes the model and runs an automatic classification and spatial location assignment for the entire model. Creates new buildings and/or stories and spaces if necessary. Optionally creates plan sections and elevations.
Note:
  • Section entities are converted to BimSection entities.
  • Simple block references can be classified.
Method
Running Bimify on the entire model will classify objects, assign spatial locations, detect spaces and create elevations and floor plan section planes in the model.
When the Bimify process is completed, an overview of the result is provided in the Command line.
This command opens the Bimify command panel.
The Bimify command panel allows you to analyze the model and run an automatic classification and a spatial location assignment for the entire model.
  1. Entities
  2. Options
  3. Feedback
Entities
Select entities in drawing
The BIMIFY command runs for the selected entities in the drawing.
Entire drawing
The BIMIFY command runs for all entities in the drawing.
Options
Discipline
Determines to what discipline the model belongs in order to improve the automatic classification.
Auto Detect
An AI algorithm determines the discipline automatically.
Architectural
The model is classified as an architectural model.
Structural
The model is classified as a structural model.
MEP
The model is classified as a MEP model.
Mixed Model
The model cannot be assigned to 1 discipline and is perceived as a mixed model.
Auto-classification
Defines the classification of solids and blocks.
Note: Also see the BIMCLASSIFY command.
Solids
Makes sure that 3D solids are classified as walls, slabs, etc.
Block References
Makes sure that blocks are classified as windows, doors, etc.
Assign structural/MEP Profiles
Assigns columns, beams, members or flow segments profiles that are available in the BIM Profiles panel.
Note: If no match can be found for a profile element in the standard library, the BIMIFY command creates a new custom profile in the project's library.
Assign spatial locations
Assigns spatial locations (buildings and floors). See the BIMATTACHSPATIALLOCATION command.
Create spaces
Detects external walls and sets the property Wall Common/is External = ON and also detects spaces. See the BIMSPACE command.
Create sections
Creates BIM Section entities. See the BIMSECTION command.
Elevations
Creates 4 elevations (Front, Back, Left and Right).
Floor Plans
Creates a plan section for each floor.
Feedback
Keep panel open and show results
If toggled, the panel will show the progress and results while calculating.
Note: This option is off by default for consistency with previous versions.
