DEFAULTSTORYNAMINGSCHEME system variable
Default Story Naming Scheme
Defines the story naming scheme for new buildings. Use $0 or $1 to control the numbering.
BricsCAD only
| Type: |
String |
| Saved in: |
Registry |
| Default value: | Floor $1 |
Note: When you add new stories to an existing building, you can override their naming and numbering by changing the value of the building's Story Naming Scheme property in the Spatial Locations Manager dialog box.
