BMWELDANNOTATE command
Creates annotates for arbitrary 2D entity in the paper space with caterpillars and welding symbols.
BricsCAD Mechanical
Icon:
Method
Select the welding symbol type and the curve from the paper space to annotate.
Option within the command
Front
Creates a caterpillar welding symbol. Select the symbol representation from the Load Linetypes dialog box.
Note: If the lines are already loaded, a warning message box is opened to agree with the replacement of lines.
Load linetype
Opens the Load Linetypes dialog box to select another symbol representation.
Select curve
Applies the caterpillar symbol on the selected curve.
Note: A preview of the caterpillar symbol is shown.
Partial
Defines a part of the curve to apply the caterpillar symbol.
Flip
Flips the caterpillar symbol side for the last selected curve.
Scale
Scales the caterpillar symbol for the last selected curve.
Side
Creates a side view welding symbol.
Fillet
Creates a fillet side view symbol.
J-groove
Creates a J-groove side view symbol.
V-groove
Creates a V-groove side view symbol.
U-groove
Creates a U-groove side view symbol.
Seam
Creates a seam side view symbol.
