CENTERLINE command
Creates a centerline.
Icon:
Alias: CL
Creates a centerline geometry associated with two selected lines or polyline segments.
Note: Centerlines are drawing reference entities to indicate
axes of symmetry.
Method
When applying a centerline to the intersection of two lines, the location of the picked points determines the direction of the centerline.
The lines and polyline segments can be selected inside blocks and in drawing view viewports. You can pick two segments of the same polyline.
Note: The centerline is associative, so when one or both lines
are moved, the centerline repositions itself.
Note: Centerlines can be edited through grips. It can be moved
and lengthened by dragging the grips. The CENTERRESET command can be used to
reset the centerline.
