CHANGE command
Changes the properties of entities, through the Command line. This command has largely been superseded by the PROPERTIES panel.
Icon:
Alias: -CH
Method
Choose one or more entities in the drawing and choose a change point which changes the size of the entity, depending on what the entity is:
  • Lines - moves the endpoint closest to the pick point.
  • Arcs - changes the length closest to the pick point.
  • Circles - changes the diameter.
  • Text - moves the text.
  • Blocks - moves the block.
Note: This option has no effect on polylines.
Options
special Entities
Specifies options for changing the properties of rays and infinite lines (xlines):
Point change for Rays and Infinite Lines affects:
change Angles
Changes the angle.
definition Points
Changes the location of the points defining the rays and infinite lines.
No changes
Leaves entities unchanged.
Properties…
Color/Elevation/LAyer/LineType/linetype Scale/Line Weight/ Thickness/TRansparency/Material/Annotative
For more explanation, see the Properties panel.
