COPY command
Makes copies of entities.
Icon:
Alias: CO, CP
方式
This command allows you to make a single or multiple copies of entities by entering a base point and a displacement vector.
Options within the command
- 位移(D)
- Specify the displacement vector (the distance at which to position the copy). ‘Vector’ means that you specify the distance and angle at the same time.
- 模式(O)
- Toggle between single and multiple copying modes.
- 阵列(A)
- Specifies the number of copies to create and the distance between each copy or the distance between the first and last copies.
- 多重(M)
- In single-copy mode only: Switches to multiple-copy mode.
- 撤销(U)
- In multiple-copy mode only: Undoes the last copy operation.
- 重复
- Repeats the copy using the same displacement.
- 退出(E)
- In multiple-copy mode only: Exits this command.
