COPYTOLAYER command (Express Tools)
Copies entities to another layer.
Creates duplicates of selected entities on a layer specified by the user. You can specify a different location for the duplicated entities.
Method
There are two methods to copy to layer:
  • Select entity on target layer.
  • Select target layer in the Copy to Layer dialog box.
Options within the command
Name
Displays the Copy To Layer dialog box that allows selecting a target layer.
Displacement
Specify the displacement vector (the distance at which to position the copy). Vector means that you specify the distance and angle at the same time.
Note: When Dynamic Input Mode is active, you can type a distance and angle in the dynamic input fields.
