-COPYTOLAYER command (Express Tools)
Copies entities to another layer.
Creates duplicates of selected entities on a specified layer. You can specify a different location for the duplicated entities.
Options within the command
 - Lists the available layer names.
 - Allows you to select an entity with the necessary layer name.
- return
 - Creates the copies in the same location as the selected entities.
