DCANGULAR command
Constrains angles.
Icon:
Constrains the angle between two lines or straight polyline segments; also constrains the angles of arcs, polyline arcs, and any three constraint points.
Methods
There are three methods to begin constraining angles:
Between two straight segments
Constrains the angle between two segments.
Of arcs or polyline arcs
Constrains the angle of an arc between its endpoints.
Between three valid constraint points
Valid constraint points are at the same geometric locations as entity snaps, such as the ends and middles of lines, centers and quad points of circles and arcs, and so on.
  1. Angle vertex
  2. First angle constraint point
  3. Second angle constraint point
  4. Dimension location
