DIMCONTINUE command
Creates dimensions in a continuous line or arc.
Icon:
Alias: DCO, DIMCONT
Creates a continuous line or arc from an existing linear, angular, or ordinate
dimension. The dimensions are based on the current dimension style.
Methods to create continuous dimensions
This command has 2 methods to begin creating continuous dimensions:
- Origin of next extension line
- Select starting dimension
- Begin creating continuous dimensions from the last linear, angular, or ordinate dimension by specifying a point for the next extension line.
- Begin creating a continuous dimension by selecting an existing linear, angular, or ordinate dimension then:
- Specify a point for the next extension line.
Options within the DIMCONTINUE command
After you begin creating a continuous dimension, the following options may be available:
- Undo
- Undo the last dimension and continue drawing from the previous dimension.
