DMMOVE command
Moves entities or sub-entities.
BricsCAD Shape; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM
Icon:
Moves solids, faces, edges or vertices of a solid or inserts using a vector.
You can select one or more entities. Press Enter to stop selecting. To specify the base and the endpoint you can choose one of the following methods:
  • Specify a point by clicking the left mouse button.
  • Type a value in the dynamic input field.
The selected geometry moves dynamically.
Note: Geometric and dimensional constraints between selected entities are taken in consideration, as well as the lower and upper bounds parameters for 3D dimensional constraints. Constraints can be accessed and modified through the Mechanical Browser panel.
