EXPBLOCKS command
Opens the Blocks category of the Drawing explorer dialog box for inserting, deleting, and creating blocks.
Icon:
Alias: XB
Note: Non-Uniformly scaled blocks can be exploded only if EXPLMODE system variable is ON.
Displays the Blocks category of the Drawing explorer dialog box:
Context Menu Options
New
Creates new blocks; dismisses the Drawing explorer dialog box, and the starts the -BLOCK command. See BLOCK command.
Delete
Deletes the block definition; available only for those block definitions not inserted in the drawing.
Insert
Inserts the selected block; dismisses the Drawing explorer dialog box, and the starts the -INSERT command. See INSERT command.
Insert External
Inserts DWG files as blocks; starts the INSERT command, and then displays the INSERT BLOCK dialog box. See INSERT command.
Save Block
Exports the selected block as a DWG file; displays the Save Block dialog box.
Right-click a block to display the shortcut menu, and then choose Options.
Add to current Toolpalette
Adds the block to the current Tool Palettes.
Options
Displays the Drawing explorer options dialog box to allow you to align, set the scale or the rotation of the inserted blocks.
Align with view
When checked, inserts the block to face the camera (blocks are rotated about their local Z-axis to face the camera).
Note: Parametric blocks cannot be cut, copied ore renamed.
Rename
Renames the selected block.
Select All
Selects all blocks definitions.
Invert Selection
Inverts the selected blocks. For instance, if you have one block selected, then this option deselects it, and then selects all other blocks.
Options within the command
Block Name
Specifies the name of the block.
Annotative
When checked, sets the Annotative property.
Match Orientation to Layout
When checked, sets the Match Orientation property of annotative blocks.
Face Camera
When checked, inserts the block to face the camera (blocks are rotated about their local Z-axis to face the camera). See the CAMERA command.
Explodable
When checked, blocks of this definition can be exploded into its component parts by the EXPLODE command. Non-Uniformly scaled blocks can be exploded only if EXPLMODE system variable is ON.
References
Reports the number of insertions of the block in the current drawing; number is set by the program, and so you cannot change it.
Insertion Point
Reports the insertion point of the block; reports "Varies" when the block has been inserted in the drawing more than once.
Parametric
Indicates if the block is parametric or not.
Linked to file
Shows file path for External Parametric blocks
Optional description of the block.
