GCCOINCIDENT command
Creates a coincident geometric constraint on 2D entities.
![BricsCAD Lite; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_US/command-reference-lite-pro-mechanical-bim.png)
Icon:
Creates a coincident constraint to ensure a point on an entity remains coincident with a specified point or entity.
Methods to create a coincident constraint
This command has 3 methods to begin creating a coincident constraint:
- Select first point
- Entity
- Autoconstrain
- Begin creating a coincident constraint by specifying a point on an entity then:
- Select second point
- Specify a point on an entity to make coincident with the first point. The point on the first entity maintains its position while the second entity adjusts, as necessary, to become coincident.
- Entity
- Begin creating a coincident constraint by selecting an entity then:
- Select a point
- Specify a point on an entity to make coincident with the first entity. The first entity maintains its position while the point on the second entity adjusts, as necessary, to become coincident.
- Autoconstrain
- Create coincident constraints by selecting all entities to which you want to apply relevant coincident constraints.
Options within the GCCOINCIDENT command
After you begin creating a coincident constraint, the following option may be available:
- Multiple
- Create multiple coincident constraints until you press Enter to end the command.
