GCCOLINEAR command
Creates a colinear geometric constraint on 2D entities.
Icon:
Creates a colinear constraint to ensure two or more linear entities remain colinear.
Methods to create a colinear constraint
This command has 2 methods to begin creating a colinear constraint:
- Select first entity
- Multiple
- Begin creating a colinear constraint by selecting a linear entity then:
- Select second entity
- Select a linear entity to make colinear to the first one. The first entity maintains its position while the second entity adjusts, as necessary, to become colinear.
- Multiple
- Begin creating more than one colinear constraint by specifying the Multiple option then:
- Select a linear entity then:
- Select entity to make collinear to the first
- Select a linear entity to make colinear to the first one. You can continue adding colinear constraints to other entities until you press Enter to end the command. The first entity maintains its position while subsequent entities adjust, as necessary, to become colinear.
