GCCONCENTRIC command
Creates a concentric geometric constraint on 2D entities.
Icon:
Creates a concentric constraint to ensure two circular or elliptical entities remain concentric.
Method
This command has 1 method to begin creating a concentric constraint:
- Select first entity
Options within the command
 - Allows you to begin creating a concentric constraint by selecting a circular or elliptical entity.
- Select second entity
 - Allows you to select a circular or elliptical entity to make concentric with the first entity. The first entity maintains its position while the second entity moves, as necessary, to become concentric.
