GCHORIZONTAL command
Creates a horizontal geometric constraint on 2D entities.
![BricsCAD Lite; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_US/command-reference-lite-pro-mechanical-bim.png)
Icon:
Creates a horizontal constraint to ensure a linear entity or pair of points remains parallel to the x-axis.
Methods to create a horizontal constraint
This command has 2 methods to begin creating a horizontal constraint:
- Select an entity
- 2 Points
- Select an entity
- Create a horizontal constraint by selecting a linear entity to make parallel to the x-axis.
- 2 Points
- Begin creating a horizontal constraint by specifying the first point to make parallel to the x-axis then:
- Select Second Point:
- Specify the second point to make horizontal to the x-axis. The first point maintains its position while the second point moves to become horizontal with the first point.
