GCPARALLEL command
Creates a parallel geometric constraint on 2D entities.
![BricsCAD Lite; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_US/command-reference-lite-pro-mechanical-bim.png)
Icon:
Creates a parallel constraint to ensure linear entities remain parallel to each other.
Methods to create a parallel constraint
This command has 1 method to create a parallel constraint:
- Select first entity
- Select First Entity
- Begin creating a parallel constraint by selecting a linear entity then:
- Select Second Entity
- Select a second linear entity to make parallel to the first. The first entity maintains its position while the second entity moves, as necessary, to become parallel to the first entity.
