GCSMOOTH command
Creates a smooth geometric constraint on 2D entities.
Icon:
Creates a smooth constraint to ensure two splines maintain fluid geometric continuity between them.
Methods to create a smooth constraint
This command has 1 method to begin creating a smooth constraint:
  • Select first spline entity
Select first spline curve 
Begin creating a smooth constraint by selecting a spline curve then: 
Select second curve
Select a second spline entity. The first spline maintains its position while the second spline stretches, as necessary, to smoothly connect to the first spline.
