GCSYMMETRIC command
Constrains a symmetric geometric constraint on 2D entities.
![BricsCAD Lite; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_US/command-reference-lite-pro-mechanical-bim.png)
Icon:
Creates a symmetric constraint to ensure two entities remain symmetric with respect to a selected line.
Methods to create a symmetric constraint
There are two methods to begin creating a symmetric constraint:
- Select first entity
- 2Points
- Select First Entity
- Begin creating a symmetric constraint by selecting a 2D entity then:
- Select Second Entity
- Select an entity to make symmetric to the first entity then:
- Select Line of symmetry:
- Select a line to act as a mirror line between the two entities. The first entity maintains its position while the second entity adjusts, as necessary, to become symmetric about that line.
- 2Points
- Begin creating a symmetric constraint by selecting a valid point on a 2D entity then:
- Select second point
- Select a second valid point on a 2D entity to make symmetric with the first point.
- Select line of symmetry
- Select a line to act as a mirror line between the two entities. The first point maintains its position while the second point adjusts, as necessary, to become symmetric about that line.
