GCTANGENT command
Creates a tangent geometric constraint on 2D entities.
![BricsCAD Lite; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_US/command-reference-lite-pro-mechanical-bim.png)
Icon:
Creates a tangent constraint to ensure curved entities remain tangent to another curved or linear entity.
Methods to create a tangent constraint
This command has 1 method to begin creating a tangent constraint:
- Select first entity
- Select First Entity
- Begin creating a tangent constraint by selecting a linear or curved entity then:
- Select Second Entity
- Select a second entity to make tangent to the first. The first entity maintains its position while the second entity moves, as necessary, to become tangent to the first entity. At least one curved entity must be selected per tangent constraint.
