GCVERTICAL command
Creates a vertical geometric constraint on 2D entities.
Icon:
Creates a vertical constraint to ensure a linear entity or pair of points remains parallel to the y-axis.
Methods to create a vertical constraint
This command has 2 methods to begin creating a vertical constraint.
  • Select an entity
  • 2 Points
Select an entity
Create a vertical constraint by selecting a linear entity to make parallel to the y-axis.
2 Points
Begin creating a vertical constraint by specifying the first point to make parallel to the y-axis then:
Select Second Point:
Specify the second point to make horizontal to the y-axis. The first point maintains its position while the second point moves to become vertical with the first point.
