LAYDEL command (Express Tools)
Permanently deletes a layer from the current drawing, with all entities on it.
Icon:
Method
Select an entity on the layer to be deleted. All the entities on that layer are deleted, along with the layer.
Options within the command
Type-it
Allows you to enter the layer name.
List
Allows you to enter the layer name(s) to list.
Lists all available layers.
Continue to delete the layer(s) ?
Yes
Permanently deletes the layer with all entities on it.
No
Exits the operation.
