LIGHTLIST command
Opens the Drawing explorer dialog box with Lights selected.
Icon:
Alias: LL
Opens the Drawing explorer dialog on the Lights category to manage the lights in the selected drawing.
Options within command
General
Defines general settings of the sun.
Intensity factor
Specifies an intensity factor that makes the light brighter or dimmer, at its source.
Sun Angle Calculator
Defines the sun angle by entering date, time and location information.
Rendered Shadow Details
Defines shadow rendering settings.
Graphic Location
Defines the graphic location.
Note: For more information about the properties of a distance light named Sun, which simulates sunlight, see SUNPROPERTIES command.
Context Menu Options
New
Creates a new layers state with a generic name.
Delete
Deletes the selected layer state from the drawing.
Note: Layer states that are used in the drawing will be deleted without warning.
Select lights in the drawing
Selects a light through the model space of the drawing.
Rename
Renames the item.
Select All
Selects all items.
Invert selection
Deselects the current selection and vice versa.
