PLAN command
Displays the plan viewpoint of drawings.
![BricsCAD Shape; BricsCAD Lite; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_US/command-reference-all.png)
Icon:
Shows the 3D model in plan view which looks straight down on the x,y-plane.
![](https://static.bricsys.com/help/images/V23/en_INTL/CMD_PLAN_01_V21.png)
![](https://static.bricsys.com/help/images/V23/en_INTL/CMD_PLAN_02_V21.png)
Options
- UCS
- Displays the plan view of a named UCS or Dynamic UCS after entering a name or placing the cursor over a 3D solid.Note: To be able to run this command the second way, make sure that the UCSDETECT system variable is turned On.
- Lists the names of UCSs in the current drawing.
- World
- Displays the plan view of the World Coordinate System.
- Current
- Displays the plan view of the current UCS.
