SETBYLAYER command
Resets overridden properties to BYLAYER.
Changes the value of overridden properties (color, linetype, lineweight, material, plot style, and transparency ) back to the default value of BYLAYER.
Methods
Select the entities whose properties will be set as BYLAYER according to the value of the SETBYLAYERMODE system variable.
Enter ‘all’ to select all non-frozen entities in the current viewport.
When entities contain blocks the BricsCAD asks whether blocks should have their properties changed.
Options
- Settings
Allows to select the entity properties to be changed from the SetByLayer settings dialog box:
- Color - resets the color of the selected entities to BYLAYER.
- Linetype - resets the linetype of the selected entities to BYLAYER.
- Lineweight - resets the lineweight of the selected entities to BYLAYER.
- Material - resets the material of the selected entities to BYLAYER.
- Plot Style - (only in drawings with plot styles) resets the plot style of the selected entities to BYLAYER.
- Transparency - resets the transparency value of the selected entities to BYLAYER.
Note: The settings are saved through the SETBYLAYERMODE system
variable.
Note: The Plotstyle option is available for STB drawings only.
See the CONVERTCTB and CONVERTPSTYLES command.
