SMFLANGECONNECT command
Closes gaps between two arbitrarily oriented non-coplanar flanges.
![BricsCAD Mechanical](https://static.bricsys.com/help/images/V23/en_US/command-reference-mechanical.png)
Icon:
Method
Select planar thickness faces of two flanges to connect them.
![](https://static.bricsys.com/help/images/V23.2/en_INTL/CMD_SMFLANGECONNECT_1.png)
![](https://static.bricsys.com/help/images/V23.2/en_INTL/CMD_SMFLANGECONNECT_2.png)
Note: If SELECTIONPREVIEW system variable is 2 or 3, thickness faces of flanges are highlighted. Press the TAB key to select obscured faces.
