TABSURF command
Creates a 3D mesh surface by extruding an 2D entity along a straight path entity.
Icon:
Method
Specify the cross-section shape (1) of the extrusion. The entity to be extruded must be open and must be a single entity.
Specify the extrusion path (2), which can be a line or open polyline. The polyline need not be a line segment. If it is a polyarc or multisegment polyline, the extrusion (3), however, is always "straight," going from the start to the endpoint of the polyline.
The path is a vector, which means its length specifies the length of the surface. Its direction specifies the direction of extrusion. The extrusion starts at the entity to be extruded, but goes in the direction indicated by the path. The end selected on the polyline or line defines the direction of the extrusion.
