TRIM command
Trims entities by a cutting line.
Icon:
Alias: TR
Method
There are two methods:
- Trims entities.
- Extends entities while holding down the Shift key.
Note: The following entities can be trimmed: lines, two and
three dimensional polylines, arcs, circles, ellipses, elliptical arcs, splines,
rays and infinite lines.
Note: Cutting entities can be: lines, splines, polylines,
arcs, circles, elliptical arcs, ellipses, rays, infinite lines, layout
viewports.
Options within the command
- Edge mode
- Toggles edge mode.
- Extend
- Trims entities that do not physically intersect the cutting entity.
- No extend
- Trim only entities that intersect.
- Projection
- Defines how intersections are projected.
- No projection
- Entities are not projected.
- Ucs
- Entities are projected according to the current UCS.
- View
- Entities are projected according to the current view plane.
- eRase
- Undoes the last trim action.
