VERSIONCONTROL command
Enables multi-user collaboration.
Enables multi-user collaboration by storing and managing projects in the cloud. Drawings are stored in the cloud using Bricsys 24/7 and checked in and out from each user's local machine.
- Log into your Bricsys account.
- Choose New Support Request.
- Open the BricsCAD menu and choose .
- In the Subject field enter: Access to VERSIONCONTROL Beta.
- Fill in the rest of the fields as needed.
- Choose Send Support Request.
Method
The first time you launch VERSIONCONTROL in a new BricsCAD session and choose one of the options, it prompts you to log into your Bricsys account.
If your account has not been granted access to the beta functionality, it directs you to a web page with instructions to request access.
If your account has access to the beta functionality, your successful login is indicated in the Command window and it prompts you to enter the name of the project on which you want to work.
Options within the command
- Init
- Creates a new multi-user project in Bricsys 24/7. If you are not already logged into your Bricsys account, the Login dialog box displays.
- CReate local
- Creates a new local version control project by entering the path of the considered folder to create a project from.
- check Out
- Checks out a drawing from your Bricsys 24/7 projects.
- CHeck In
- Checks in drawings from your local version control folder to the associated Bricsys 24/7 project.
- Update
- Syncs project drawings from your local folder with the associated Bricsys 24/7 project.
- Revert
- Reverts to previous state.
- REname
- Renames a drawing that is under version control.
- History
- Enables you to go to older versions.
