XFACES command
Extracts faces from 3D entities.
![BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_US/command-reference-pro-mechanical-bim.png)
Icon:
Makes copies of one or more faces from one or more 3D solids and 3D surfaces.
Options within the command
- Move
- Move the extracted face/s by the distance indicated by two points or by a displacement vector.
