Geographic location dialog box
The Geographic Location dialog box allows you to set the geographic location of the drawing by applying the longitude and latitude to a point in the drawing.
  1. GIS Coordinate System
  2. Latitude / Longitude
  3. Position
  4. North direction
  5. Elevation
Reports the GIS system being used by the drawing.
Note: Click the browse icon to change the system.
Store geographic location information in drawing
When checked, a red dot indicates the position in the drawing.
Use Map Grid coordinate system
Uses the location data from the GIS Coordinate System.
Choose Location
Specifies the graphic location through the Choose Geographic Location dialog box.
Degrees Minutes Seconds Lat/Long
Displays the location in a Degrees, Minutes and Seconds format.
Decimal Lat/Long
Displays the location in a decimal format.
Latitude
Sets the latitude. The valid range is 0 to 90.
Longitude
Sets the longitude. The valid range is 0 to 180.
Time zone
Specifies the time zone from the Time Zone drop list.
Note: This setting is saved to the TIMEZONE system variable.
Position
Specifies the position of the location in the drawing by entering coordinate values.
Note: You can also select a specific point in the workspace to set the position.
North direction
Specifies the angle of the sun from north, in the context of the world coordinate system.
Note: The setting is saved to the NORTHDIRECTION system variable.
Elevation
Specifies an elevation for the long-lat point. The value can be positive or negative.
