Drawing traces
Traces are 4-sided filled entities, created with two parallel sides. When you create a series of traces, they are L-connected to each other.
The Trace tool is available on
  • the Draw menu.
  • the Draw ribbon panel
The default trace width is saved through the TRACEWID system variable.
General procedure
  1. Launch the TRACE command.
    Prompts you: Width of trace <current width>:
  2. Do one of the following:
    • Right click to accept the current width.
    • Type a value, then press Enter.
    • Define a new current width graphically by clicking two points.
    Prompts you: Start of trace:
  3. Specify the start point of the trace.
    Prompts you: Next point:
  4. Specify the end point of the first trace.
    A line indicates the direction of the first trace.
    The direction of the second trace displays dynamically.
  5. Do one of the following:
    • Right click to create the trace.
    • Specify the endpoint of the next trace.
  6. Do one of the following:
    • Repeat step 5 to keep adding traces.
    • Right click to stop.
Note: When the FILLMODE system variable is turned off, all filled entities, such as traces, display and print as outlines.
