Annotative leaders
Multileaders are created using the current Multileader style:
- If the Multileader style is annotative, the Multileader entity gets the annotative property automatically and the current annotation scale is assigned.
- If the Multileader style is not annotative, you need to make the Multileader entity annotative manually.
To make a Multileader entity annotative
- Select the Multileader entity.
The properties of the selected Multileader entity are displayed in the Properties panel.
- Select the Annotative property.
- Choose Yes in the options list.
The current annotation scale is assigned.
The Multileader entity is scaled with respect to the current annotation scale.
To remove the annotative property
- Choose No from the options list.
