BricsCAD user files
In BricsCAD user files are stored in specific folders:
  • PlotConfig: plotter configuration files (*.pc3)
  • PlotStyles: plot style table files (*.stb) and plot color table files (*.ctb)
  • Support:
    • hatch pattern files (*.pat)
    • line style files (*.lin)
    • alias files (*.pgp)
    • unit files (*.unt)
    • custom user interface files (*.cui)
    • BIM library files (*.bsyslib) see BIMPROJECTINFO command.
    • Structure tree configuration files (*.cst) see STRUCTUREPANEL command.
    • Library panel configuration files (*.ccf) see LIBRARYPANELOPEN command.
  • Templates: template drawings (*.dwt)
Platform Folders Subfolders
Windows C:\Users\<UserName>\AppData\Local \Bricsys\BricsCAD\<Version>\en_US \Templates
Windows C:\Users\<UserName>\AppData\Roaming \Bricsys\BricsCAD\<Version>\en_US
\PlotConfig
\PlotStyles
\Support
Mac /Users/<UserName>/Library/Preferences/Bricsys/BricsCAD/<Version>/en_US
/PlotConfig
/PlotStyles
/Support
/Templates
Linux /home/<UserName>/Bricsys/BricsCAD/<Version>/en_US
/PlotConfig
/PlotStyles
/Support
/Templates
The BricsCAD user file manager
When you update, the first time you launch BricsCAD after the update, the content of the UserDataCache subfolder of the BricsCAD installation folder is compared with the content of the user file folders. If you have customized files in these folders and if one or more of the corresponding files in the UserDataCache folder are more recent, the BricsCAD user file manager dialog box displays, asking you whether to keep or to overwrite your files with the new version.
Do the following:
  1. For each file in the list, choose what to do:
    • Keep current: keep your customizations.
    • Overwrite: replace the file.
  2. Click the Accept button.
