Array Properties
Overview
Component array is an associative array made of a parametric component. Component arrays have a special representation in the Mechanical Browser.
Component array have 2 main subnodes:
- Source: node that contains source object and its parameters. Source object can be presented as a component or subassembly with specific properties.
- Elements: node that contains all instances of source object.
Component array context menu is displayed by a right click on the array node, while array properties are displayed automatically when selecting an array in the Mechanical Browser.
Context menu | Description |
Component array context menu | Right-click an array:
Related commands
Command | Description |
3DARRAY | Create 3D arrays. |
ARRAY | Create a polar or rectangular array of entities; display prompts at the Command line. |
ARRAYCLASSIC | Create a static polar or rectangular array of entities through a dialog box. |
ARRAYEDIT | Edit associative array entities and their source entities. |
ARRAYPATH | Associatively distribute entity copies evenly along a path into multiple rows and levels. |
ARRAYPOLAR | Associatively distribute entity copies evenly in a circular pattern about a center point or axis of rotation, using multiple rows and levels. |
ARRAYRECT | Associatively distribute entity copies into any number of rows, columns, and levels. |
MINSERT | Insert arrays of blocks. |
