Animation editor panel
The Animation Editor panel allows you to create schedules for multi-parametric animations with complex camera movements and render them as 2D videos.
Add scene
Render video
Opens the Render video dialog box to specify the render options:
- Render frame rate (fps)
- Sets the frame rate of the video.
- Resolution
- Sets the resolution of the video by selecting it from the drop-down list of supported resolutions.
- File format
- Sets the format of the output video. You can select a file format from
the drop-down list:
- avi (AVI Animation)
- mpg (MPEG Animation)
- wmv (WMV Animation)
- Start time
- Sets the time position of the animation to start the render.
- End time
- Sets the time position of the animation to end the render.
After pressing the Render button, the Save Video As dialog box opens to allow you to save the rendered video.
Record graphics for the current scene
Records animation graphics and saves it to zip-archive or to folder of your choice.
Load animation graphics
Loads animation graphics data from zip-archive or folder and opens the special mode for playing this graphics.
Configurator
Toggles the configurator panel.
Add timeline
Adds the selected parameter to the timeline.
Disable/enable timeline effects button
Toggles the timeline effects between enabled and disabled. Disabled timeline effects are excluded from the animation.
Lock/unlock timeline button
Toggles the timeline to lock any timeline changes or vice versa, to enable changes.
Slider
Move the slider to zoom the timelines.
