ATTREQ system variable
Insertion default settings
Specifies whether default attribute settings are used by the INSERT command during block insertion.
Tipo: |
Booleana |
Salvato in: | Registro di sistema |
Valore predefinito: | 1 |
Valori possibili: |
Off (0): Use default values On (1): Prompt user |
