AUTOADOPTSIZES system variable
Auto adopt sizes
When On, the wall width and height, and the slab thickness is copied from the highlighted existing geometry, when using BIMQUICKDRAW.
Tylko BricsCAD
Wpisz:
Boolowskie
Zapisano w:
Rysunek
Domyślna wartość:
Na
Możliwe wartości:
Off (0): The wall width and height, and the slab thickness is not copied.
On (1): The wall width and height, and the slab thickness is copied.
