AUTOMATICTEES system variable
Automatic tees
Controls automatic creation of the tee flow fitting in case of T type connection in the BIMFLOWCONNECT command.
BricsCAD only
Type: |
Boolean |
Saved in: |
Registry |
Default value: | 0 |
Possible values: |
Off (0): Disable On (1): Enable |
