BACKGROUNDPLOT system variable
Background plotting
Specifies whether background plotting is enabled for plotting and/or publishing. The value is stored as a bitcode using the sum of the values of all selected options.
Type:
Short
Saved in:
Registry
Range:
0 to 3
Default value:
2
Possible options:
0: None
1: When plotting (Not supported)
2: When publishing
