BLOCKIFYMODE system variable
Blockify settings
Defines the behavior of the BLOCKIFY and PARAMETRICBLOCKIFY commands. The value is stored as a bitcode using the sum of the values of all selected options.
BricsCAD only
Type:
Short
Saved in:
Registry
Range:
16 to 247
Default value:
48
Possible options:
1: Use entire drawing as search space
2: Use default block insertion point
4: Use default block name
32: Compare geometry only
64: Convert unique solids to blocks
128: Show preview
