BLOCKIFYTOLERANCE system variable
Blockify tolerance
Specifies a relative tolerance used in the BLOCKIFY and PARAMETRICBLOCKIFY commands for determining whether two entities are equal. An example of a relative tolerance is the maximum ratio of the difference between two line lengths to the length of one line. A negative value means the algorithm will determine the optimal tolerance itself (0.000001 for 2D and 0.0003 for 3D entities). This option is highly recommended.
BricsCAD only
Type:
Real
Saved in:
Registry
Default value:
-1.0
