COMPONENTSCONFIG system variable
Library panel configuration
Name of the active Library panel configuration file. This file contains which libraries are shown in the components panel. SRCHPATH is used for finding the file.
BricsCAD only
Type: | String |
Saved in: | Workspace |
Default value: | default.cct |
