DMRECOGNIZE system variable
Automatic 3D geometry constraints recognition
Specifies which geometrical relations between the surfaces are maintained direct modeling operations. The value is stored as a bitcode using the sum of the values of all selected options.
BricsCAD only
Type:
Short
Saved in:
Drawing
Range:
-1 to 1023
Default value:
0
Possible options:
Negative: Switch off automatic 3D geometry constraints recognition
1: Tangent surfaces
2: Coincident planes
4: Parallel planes
8: Perpendicular planes
16: Cylinders perpendicular to planes
32: Coaxial surfaces
64: Cylinders and spheres of equal radius
128: Vertices between 4 or more faces
256: Edges between coincident faces
512: Fix a constrained plane lying in XY/YZ/ZX (compatibility)
