HPTRANSPARENCY system variable
Default transparency for new hatches
Specifies the default transparency level for new hatches.
Tipo: | Stringa |
Salvato in: | Disegno |
Valore predefinito: |
Valori possibili: |
.: Use current ByLayer: Apply the layer’s transparency ByBlock: Apply the block’s transparency 0: Apply no transparency (fully opaque) 0-90: Apply transparency percentage from least (1) to most (90) transparent |
