IMPORTINVENTORSEARCHPATHSPREFERENCE system variable
Search paths preference
Defines priority order of search paths.
Note: This option is taken into account only when import in
background is enabled (CommunicatorBackgroundMode system variable is ON).
BricsCAD only
Type: |
Short |
Saved in: |
Registry |
Range: |
1 to 3 |
Default value: |
1 |
Possible options: |
1: Sub-folders first 2: Root folder only 3: Root folder first |
