MASSPREC system variable
Mass precision
Specifies the number of decimal places displayed for masses when the mass bit of PROPUNITS is on. If negative, LUPREC (Linear Unit Precision) is used.
BricsCAD only
Type: |
Short |
Saved in: |
Registry |
Range: |
-1 to 8 |
Default value: |
-1 |
Possible values: |
-1: Use LUPREC 0: 0 1: 0.0 2: 0.00 3: 0.000 4: 0.0000 5: 0.00000 6: 0.000000 7: 0.0000000 8: 0.00000000 |
